runs longer and not hot like before
Hi all .I bought this house and this dish washer bosch shu5315uc/uc 12 was in it.So don’t know how old is it .worked for a week then runs never stops, i checked the control panel i found burned spot i solder it and it worked great for like 2 weeks. but now it runs 3 to 4 hours until is done but it is not hot the plates or when you open it no steem even before i could feel the heat on the front door .i do run the hot water 1st and then i turn it on to make sure is getting very hot water.
Any suggestions or how do you run diagnosis on these to get the code if some thing is broken ?or if any one know the solution right away i really appreciated.thx again.
