Okay, been searching the forums and can find answers, but not the exact answer.
Background:
Had a power surge/outage about 3 weeks ago.
Problem:
Freezer and frig went out. Replaced control module/motherboard, as it was physically smoked. Unit started up and everything worked fine. The damper motor did however make a clicking sound until the frig side started to cool, and then it quit, now Freezer is cold, frig is not. Evap coil is iced over.
What I have done to date:
As stated, replaced control module/mother board.
Checked defrost thermostat when cold, it has continuity, opens up at room temperature.
Checked defrost heater, it has continuity.
Found out through a search here that the small clear coated wire loop taped to the freezer t-stat probe is probably the evap thermistor. It has 6.5 ohms at 76 degrees, room temperature. This thermistor does not show up as a part number on the parts list on section 5.
Checked both t-stats manually, and they open and close and have continuity when switching all the way from off to extreme cold setting as the dial is turned.
As I said before, evap and condensor fans are working, and the unit was cooling along just fine, then yesterday I noticed the temp in the fridge rising, snow in the freezer compartment, all the usual suspects for typical problems I have seen on here. removed back cover and the evap coil is iced over. Damper door was not working…
Any ideas what could be wrong…
Thanks,
Tom
