self defrost-water buildup
I have a Whirlpool fridge with the freezer on the top. Both freezer and fridge seem to be cooling fine, and there is no ice buildup in the freezer. The problem is I am getting a water-ice buildup on the top shelf of my fridge? I pulled it out and cleaned all the coils but it was there again today. I assuming it is coming from the freezer self defrost?
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it’s stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
