The dryer does not turn off when using the sensor drying cycle. The clothes dry but the dryer just doesn’t shut off automatically, nor does the dial change as the cycle progresses. The time dry cycle works fine as does everything else about the dryer. The repairman changed the moisture sensor yesterday but the problem has continued. What else could the issue be?
drew
