shakey washer
washer works, but, shakes violently, like it is out of balance. Just replaced the clutch and also, replaced the drive coupler
— Begin quote from pltdaddy;822901
does nayone have any sugestions to fix this problem.
Check the position of the suspension plate, check the damper pads on the base assembly and the suspension plate. Check the 3 suspension springs and the counterbalance spring. Check the drive block. Could also be clothing between the tubs, fluid leaked out of the balance ring.
Eric
