shelly
My dishwasher seem to not be getting hot or drying the dishes. When the cycle is done all the dishes have alot of water and seems like a residue on them, I’m wondering how I would know if this just might be the heating element. I got a small part(maybe fuse) but cant seem to see where to replace it. so thought I see what my next step is. thanks shelly
Here is your tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Unplug or remove power from the unit
Remove the kick plate.
Remove one wire from the heating element.
Measure the element with a meter
Should be approximately 20 ohms.
If OK
Remove one wire from the hi-limit thermostat and measure it.
Should be 0 ohms
Not sure about the above, where did you get it from?
There is a thermal fuse in the unit but it kills power to the unit.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
It was pretty weird. I gave up and called a repairman. But over the weekend, before I shoved it back under the counter, I took another look underneath. By just chance, I noticed that the wiring terminal connected to the motor didn’t look like it was pushed on tightly. Could it be that simple? I pushed the connector in tight, shoved the unit back under the counter and it was fixed! I can only guess that the wiring connector had vibrated loose. I called early Monday and cancelled the repair call. Check the wires to the motor! Good luck
