The unit initially pumps water out, some water comes in and then nothing. Ten minutes later if I open it there is just some luke warm water in the bottom. Replaced the control board which didn’t fix it.
Appreciate any suggestions.
Does the circulation pump ever run? There are two motors, one for drain and one for pumping the water around inside. Just in case…
https://www.appliancepartspros.com/bosch-circulation-pump-442548-ap3842231.html
