Side by side freezer with 3 problems
I have 3 problems with the freezer of my Kenmore side by side: 1. the ice maker does not produce ice 2. It is leaking water and building up ice on the bottom of the freezer 3. Now it looks like a winter wonderland inside–there is "snow" inside the freezer. I also noticed the freezer temperature is at the bottom of the thermometer–way below the normal freezer range and the thermostat is on "5".
Sure: model 52603100 (Kenmore Elite side by side). Last night I carefully stuck a wire in to the drain hole and also flushed it with some diluted vinegar water. I watched it drain very easily in to the drain pan. I have also cleaned the coils recently and changed the water filter. Thank you so much for your help. I don’t know how you all keep up with all of the requests.
