***Silent Partner ii will fill up with water and drain but will not wash dishes!!***
I have had my dishwasher since 2010 but have never used it since I have not had the money to hook up the electirical. Just two days ago I had every thing hooked up and attempted to run a cycle. After the cycle was "done" I checked the dishes and nothing had been cleaned. When I first started the cycle water appeared to be filling in the tank. Approx 10 min later of not hearing any movement of water it drained the water leaving all of the dishes uncleaned.
When I opened the dishwasher door to see if the dishes were clean a small about of steam emitted from the inside of the dishwasher. When I felt the water it appeared to be hot as it would normally be but none of the dishes were wet. When looking at the controll pannel all LED grean lights are solid and not blinking.
Please help if you have any words of advice. Thank you
I would check the main motor to see if it the wire harness is still connected to the motor.
