The tub will slowly (drip by drip) fill up if the hot water valve is left open. I disassembled & cleaned the solenoid bank under the control cover but it still leaks. I don’t want to buy a new set of solenoids if that’s notgoing to fix. The part I think I need is
AP3861119
thanks for any help
Check to see that 120v is getting to the valve when it is supposed to be open. If so, try replacing it and see if that does not solve your problem. Also check that you have full water from the hot water faucet.
If you buy the part from this site and it does not fix your problem you can return it. See the returns policy or check with APP when you order.
