I have a maytag MOR5730BDW that is slow to ignite, so the gas comes out and then when it does ignite it flares up momentarily.
Hi.
If the correct model number is MGR5730BDW you should check the oven ignitor’s amps draw.
If it’s less then 3.2 amp - replace the ignitor. Check if the burner pilot lights are not blocked and the burner ignites evenly.
The ignitor [part]74007498[/part]
Here are the breakdown diagrams and Replacement parts for Maytag MGR5730BDW RANGE- S/C F/S GAS | AppliancePartsPros.com
Good luck. Post the results.
Simon.
