Hello,
I have an LG french door fridge and the water flow has slowed to about 1/3 of what it used to be. Only 2 years old. Water is on a softener system.
Water Inlet —> filter —> door tube connection on back of fridge –> Ice maker /water dispenser
Here is what I know:
- Good water flow and pressure at the fridge inlet
- Filter has been changed with no change in the condition
- Water is slow post filter and before the fridge door. (Disconnected the rear tube pre-door/ice/water dispenser and flow is poor.)
I assume I either have a blockage before or after the filter or is it possible the solenoid is bad/ weak? How would I go about cleaning the line or checking the solenoid?
Thanks in advance!
-A
