LG top load washer: I lost a small screwdriver bit (5/16" x 0.75") in the laundry. I initially discovered it after some removing the top drum cover/trim between the inner and outer drum. I thought i could fish it out, but then it slipped down under the inner drum. The washer is brand new. Less than 5 loads of laundry. I would hate to tear the thing apart more than I have. Does anyone have any idea what i can expect if I do nothing more. Since it slipped under the drum it is no longer making the noise it was when it was stuck between the inner and outer drum on the side. Is it possible the pump will discharge it and i can catch it if I put a screen on the discharge, or will it even make it to the pump from where i last saw it?
Related topics
LG Washer Part What is it, where does it go? | 2 | 468 | May 4, 2017 | |
LG top load help needed | 2 | 166 | March 29, 2022 | |
LG Inverter Direct Driver Top Loader | 1 | 139 | July 22, 2021 | |
LG Front Load Washer died mid-cycle. Stuck | 1 | 743 | January 2, 2016 | |
LG washing machine just stopped! | 2 | 1852 | June 7, 2011 |
