snow (frost) all over food in freezer
replaced everything except evap fan motor ? please help:confused:
and ice cubes freeze together
applirefurbguy said:
…replaced everything except evap fan motor…
Which parts exactly did you replace?
What was the original problem?
What is exact temperature in the freezer and in the refrigerator?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5207477
— Begin quote from applirefurbguy;394975
i replaced heater and defrost t-stat, main board, and evaperater sensor
— Begin quote from applirefurbguy;397074
0 degrees in freezer and 50 in refrig
You may want to check the damper control (#426 on the diagram).
