I just got this, it worked fine but I noticed there is no lint trap, so I began fishing lint out of the hole, I pulled out quite a bit of lint, wrappers and a sock, I ordered a new lint trap, but I think there may be more inside, how do I check, how can I take the dryer back off to see also if there is a build up of lint inside, there was some around the drum when I looked through the small door on the back. I dont want to ruin this dryer.
You work from the front to fix this puppy.
pop the top and remove the front.
Get the tub out.
the element is located on the rear of the dryer.
The element can be restrung for a lot cheaper price than buying the whole pan with element attached.[ATTACH]207[/ATTACH]
Ok how do I pop the top? I have no idea!! Please someone help me. I think I ruined the heating element anyhow, it doesnt get hot now, so much for my do it myself project, but now I need to know how to get to the heating element. Its an electric dryer by the way.
Go along the outer edge between the front and the top and use a putty knife. Press against the clips located 2 inchs from either side of the dryer. while lifting upwards on the top. It should just release.[ATTACH]214[/ATTACH]
