Sounds fine but no heat
Hi all, my microwave sounds like normal but doesn’t heat anything. I don’t know if its worth fixing or not, it also has a cracked door frame, (plastic outer cover). The problem is that it is built into the cabinet, using a trim kit and I don’t know if I can find one that will fit back in the hole or not. Any suggestions?
Thanks in advance,
Mike
Hi Mike, You WON’T want to hear it !!! But I would just replace it. New ones are less than $200. :frowning:
Thats what I was thinking but the problem is if I can find one that will fit back in the hole, thats going to be the hard part.
They are ALL 30" wide!!! with slight diff. in height.:slight_smile:
