Spin Cycle
Does Anyone Have Any Info On What Horrible Sound During Spin Cycle Can Be? Sounds Like Jet Engine. Everything Else Works Fine. Wondering If Worth Trying To Repair Or Just Buy New One. It Is An Lg Washer. 5 Yrs Old No Warranty On Labor Only Motor And Tub.
Typically that noise like a low flying airplane is your bearing out on the tub or the spider is damaged. Here’s a couple video’s to help you determine it. Easy way to tell is grab the drum (metal part) and the tub the plastic part surrounding it and see if you have alot of free play you shouldn’t have barely any movement bringing those pieces closer to each other. Also check in the rear of the unit see if you notice any rust or water seeping out the rear of the tub where the shaft comes out. If so your bearings or seal are shot and your machine needs a complete rebuild
http://www.youtube.com/watch?v=OThhUNI0oL8
http://www.youtube.com/watch?v=oLG65KweGYc
