Spin Leak
The washer leaks a little when it spins out. The leak appears to be coming from between the inside liner and the outside shell, in the rear from under the hose connectors. Do I take the back off (how?) and inspect the above area? What should I expect to see if all is normal? Do I need special tools? (I have a few basic home tools.)
The washer leaks almost every load, but particularly if I miscalculate the load size…too much water for too little clothes.
