spin
everything works except the spin cycle. Ive replaced the timer and it still does the samething.Its a GE Profile about 7 years old. Any suggestions would be appreciated
Thanks Bob Allen
Bob, it sounds like a drive problem. Is it direct drive or belt drive?
Also the clutch can get bad, allowing agitation, but no spin after rinse.
Hi, Bob.
In order to provide you with correct diagnostics and the parts to fix the problem we need a complete washer model number.
Thank you,
Simon.
