Spinner Block Stuck in Basket
When I removed the basket the spinner block is in the basket and I can’t get it out. I have never seen a good one before amd I don’t know exactly what it should look like, ? It has a quarter inch crack on one side going down as fa as I can see into th basket. I tried driving it out from the other end of the basket. but it didn.t budge.I sprayed a good loosener in the crack, and still no luck.
Does this happen often??::confused:
The drive block usually stays in the spin basket when you pull out the basket. When you put back the basket, make sure the spin tube tabs fall in the drive block slots, just turn the basket to allow this.
