General Electric gas dryer makes a clunking sound once per revolution with and without a load. I have disassembled it and can’t find anything obvious.
Later:
When taking off the rear bearing shaft assembly and heat diffuser found the bracket that holds the rear bearing assembly was cracked and almost completely detached.
