I replaced thrust bearing kit and belt. The washer is still having difficulties spinning. As it almost reaches top speed it becomes off ballance, thunks/clicks, stops, and then starts to spin again. The clothes are a little wet when finished. Maytag Atlantis washer
I don’t have a wiring diagram for this model, but it sounds like there is an unbalanced load switch kicking in. Run it with the front cover off and see if you can tell why the basket is moving around and tripping the switch.
