I have a electric dryer that has been making a loud high pitch squeaking noise. Sometimes it does it and sometimes it doesn’t. It has been more consistent lately that it is doing it more often. Well a couple days ago it started making a thumping sound like shoes are in the dryer. I can take everything out of the dryer and it still makes the sound. I took the top off and looked to see if anything was loose or hanging and nothing looked out of the ordinary. Not really sure what i was looking for just anything obvious. Don’t really know how to take the back off. Any thoughts on what this could be and maybe a tech manual on how to take this thing apart?
You want to attack this from the front. After you lift the top you can take off the front by taking out the screws that hold it to the cabinet.
Use the belt to lift out the drum, and replace the rear bearing, belt and idler.
That should do it.
