squealing when dryer is on
This dryer will squeal as it is turning. It drys just fine. the sqealing is annoying. Is there something that needs lubrication? or do I have a bearing or belt tennsioner going bad
Replace the REAR DRUM BEARING, Lube the idler pulley and it will be good for another 5 yrs.
