Squealing
When the dryer is turned on there is an ear piercing squealing noise when the drum is turning. What could be causing this problem?
Take the dryer apart and check all moving parts (drum support rollers, idler pulley etc) and the tumbler bearings (#30 on the [B]Service manual[/B].
Here is the [URL="http://servicematters.com/maytag_library/docs/16023110.pdf).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46717
