Stacked Maytag Gas Dryer
The bottom gas dryer is not getting hot. I ran the dryer in diagnostics mode and the dryer does not get hot at all. The ignitor is glowing red. I replaced the two coils for the gas valve and the dryer still does not get hot.
I am thinking that my next step is to replace either the radiant sensor or the Hi Limit thermostat. Please advise.
Hi.
Does the ignitor switching on and off? If it’s not - replace the flame sensor.
If it does and the gas to the dryer is open - you have bad safety gas valve.
The flame sensor [part]338906 [/part]
The gas valve [part]308345 [/part]
Here are the breakdown diagrams and Replacement parts for Maytag MHG15PDAWW MANUAL, PARTS (DRYER GAS) | AppliancePartsPros.com
Thank you. Post the results.
Simon.
