start switch give a good growl but motor not starting
When I rotate the start knob, I get "the Growl" by the switch but no motor start. Rotated drum by hand…no change where do I start?
thanks
tom…tools and multimeter in hand!
[SIZE=3]No you can’t replace the start switch. However I have repaired many dryers the way you described (cleaning contacts) I think you are ok. If the dryer does the same thing again soon I would recommend changing the motor. http://www.appliance-repair-it.com/clothes-dryer-repair.html[/SIZE]
I just ordered a new gasket for the refrig door (old one mangled at bottom) I am hoping this is why water is condensing and leaking to the floor. After ordering, it occurred to me upon further inspection… How do I attach the gasket to the door once I get it!!! Appliancely Inept, Mark
