After I push the start button,water will start to flow for less than 5 or 10 sec.,then the washer will turn off.
Check the main control board for any burn’t components. If you find one you will have to change out the board and the wax motors.
My washer serial no. is 11286389WF
I am getting an error message when I try running the unit saying "a problem has been detected with this unit".
