Hello, anyone have any thoughts? The timer knob appears to advance when it’s in the ‘timed dry’ mode but when it’s in the automatic more dry/less dry mode the dryer seems to run and never turn off even though the clothes are dry. How does the more dry/less dry mode work? Is there a sensor of some type that tells the timer to run or turn off? If there is a sensor is it inside the timer or is it located some other place in the dryer? Any help would be very much appreciated.
Thank you
