steve
when I start dryer[gas] it gets hot for about 10 minuets then cools down and won’t get hot again unless you wait 15 minutes or more.All the info I have seen points to the igniter / coil area, since it gets heat isn’t the igniter working to initiate the heat?
If igniter and or coils are to be replaced can someone explain how / where to locate and is it best to replace as an assy, or replace coils only.
Steve
