Machine runs but does not continue to next cycle, light says heating delay. Turned off high temp rinse, and high temp wash, left heated dry on. Machine still did not continue to second cycle but after manually moving dial, completed other cycles and dry. Hot water to machine is 125 d. Dishes are always clean and dry, just have to move dial to get to next cycle.
Try to do next:
Unplug the range for a few minutes, plug it back, push and hold the light switch on the oven door frame (you can tape it) and start the clean cycle.
If the door latch will move, let him go forth and back and then cancel the clean cycle and wait until the door latch is completely open. Remove the tape from the door switch.
If the door latch would not move, most likely the door latch motor assembly (#89 on the [AP3873473](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=339253&&model_id=111725"]Body break down diagram[/URL]) has to be replaced.
The part number for the door latch motor assembly [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3873473&&model_id=111725&diagram_id=339253)
Here are the break down diagrams for the Frigidaire range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=339253&&model_id=111725
Good luck.
The lights below the unit near exhaust intake will not turn on. We have replaced the bulbs. The rest of the unit functions as designed.
