Stove top lighting troubles
The lighting on the bottom of my GE spacemaker microwave is giving me problems. The light on the right side stays on no matter how many times I press the on/off button. The light on the left will not come on. I did replace the bulb that is not working it didn’t make a difference. It was working correctly the last time I used it. Can someone tell me how to fix this?
The surface light in your microwave operates by the control board which has to be replaced in order to fix this problem.
  • The part number for the control board is AP2025946
Here are the break down diagrams for the GE microwave http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=459535&&model_id=216802
