stove top works/clock on/oven controls dead
just replaced the oven control module still getting error code PF I have the 240v
to the board the question i have, would the keyboard(touch panel) cause this problem, it is attached to module through a membrane connector is there a way to test these switches?
sounds like your saying keypad is not the problem customer says when power outage occurs stove always came back with PF when power restored, until he pushed the cancel button so i take it the keypad OR membrane if defective we would be getting this PF and cannot clear it
Remove keypad ribbon cable and turn power on, if now no problem, replace keypad.
Click on your model # to get it.
We have a side by side frigidaire, which retains at least an inch of ice on the freezer side and an inch of water on the fridge side. It appears that this model doesn’t have a proper drainage system.
Unfortunately these parts are not interchangeable and if the old burner is really broken, I do not see any alternate.
