Burners on stove top will not ignite. I have to use matches. Oven will not light evan with matches. I do not hear no clicking at any time what part or parts should I replace?
It sounds like you have a bad spark module. You need to find the model #, so we can tell you a part#. Look around the oven frame, where the door closes against, or under the top, where the burners are if your top comes up, or around the broiler draw. Tom
Hi Wendy
Take off the cabinet and check the suspension plate and other suspension parts to see if anything is out of whack.
This web site will show you how to open your machine, assuming you have a basic Whirlpool direct drive model.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
If you find everything ok, replace the three suspension springs.
