Ok, now the cycle completed. The dishes are still dirty. The soap cascade pod I found in the silverware container not dissolved. It worked fine before with the pods.
Other thing we noticed is the new keypad has a 14-pin connector to the board. The original has a 15-pin connector. Did we get the wrong keypad?
The correct model number is GU2700XTSS0 and it calls for the same parts that I ordered and installed. But the dishwasher is not working right. Any suggestions?? Please help!
Customer service is telling me that the water valve may have failed and that caused the board to fail which was my original problem. So we will check the power to that valve and go from there.
Water inlet valve solenoid was ok but I found some other forums that said it to replace it anyhow. It is on order now. We ran a test and no water was coming into the washer.
I will keep this thread going until we get the durn thing working.
It did not blink 7 times. and I can tell the heater works when I open the door.
So I tried a "light cycle" with just a few dishes. It seemed to run ok then stopped with 58 minutes on the timer. I cancelled it and opened the door… there was steam inside so I ran the cancel/drain.
I do not know what to try now. We have spent over $300 on parts, my hubbie is an electrician so we know how to deal with most appliances.
Ok, trying Normal cycle. Seems to be running but it stopped at 97 minutes to go again. No sounds from it. No blinking lights, Just the Normal and Start lights on solid.
It is filling with water and the water is heating up, but should it stop so long (10-15 mins) at this point?
It is down to 42 mins on the timer, but the time is not coming down with the clock time on the wall. Is this "normal" or do I have a bad board? Please reply with something that makes sense.
no "Clean" light at this point. But the Normal cycle has been running for > 4 hours now.
Where did my messages go? I added that I was stuck again at 97 mins and currently at 44 mins after The "normal" cycle has run over 4 hours total. What is your recommendation as to a fix?
I think I will just return the parts and get a new dishwasher. I find new ones around $400 that will do the job. If the pump is the problem, I think it will cost too much to justify trying it. We did take off the lower arm and the chopper appeared to be OK. It just seems we go from one "fix" to another on this machine.
