Today while baking with the top oven in the normal way the upper (broiler) element would not shut off. I tried everything that I could think of to shut it down but it would not respond. I had to trip the breaker in the electrical panel to get it to shut off. Two hours later I turned the breaker back on and the element came back on even with the door open. Is there a relay that might be stuck, a defective thermostat, or some other part that I might be able to replace to fix my problem?
The relays to control the functions of the elements are on the appliance’s electronic control (see the link below). If one was shorted causing an element to always stay on, the control would usually need to be replaced to correct the condition.
LINK > http://www.appliance411.com/data.php?ap=AP3767567
Oven elements wouldn’t usually shut off just when the door is opened even in a correctly operating appliance.
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=Whirlpool+Oven*The Appliance Information Site*
=D~~~~~~
I have received the control board and wondered if there is an instruction sheet or something that will step me through the process of installing the new board.
Other than an instruction sheet which might pertain to and be included with the control itself, I don’t know of where you’ll find detailed repair instructions for that job, sorry.
Dan O.
http://www.appliance411.com/parts/?ref411=Whirlpool+Range*The Appliance Information Site*
=D~~~~~~
— Begin quote from Dan O.;105091
Dan O.
www.Appliance411.com
=D~~~~~~
Thanks anyway. I’ll give it a try and get back to you.
mnames
Glad to hear it. Thanks for the follow up.
Dan O.
=D~~~~~~
