stuck in heavy wash , drain position
Unit is stuck at heavy clean , drain cycle . If I remove power and turn back on it goes back to that cycle . Door open , same cycle . Power tab to off and it immediately returns to same cycle. Attached new touch pad , same condition .
Tried new control board , same . New board and new touch pad , same . Put water in tub , same ( water did drain out ) . ???
