Stuck on 60
My dryer sits there all lit up like it’s ready to go and has 60 mins showing in the readout, but it is just fooling me because when I hit start it still just sits there, on 60, doing nothing, all lit up. None of the other buttons change any settings, seems she’s froze up. Any ideas would be appreciated.
Have you tried unplugging it for 5 minutes or so to see if it will reset?
— Begin quote from denman;452263
Hey thanks for the reply. Actually it has been off for several days, been using a friends dryer as backup. When plugged back in it always displays as described.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE5500AYW
Here is a service manual
http://appliancedigest.com/index.php?/files/file/81-16023110-maytag-sloped-front-dryer-repair-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Try to get into diagnostics to see if any thing will come up.
If no joy, I would try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
If no joy then odds are that the control board is shot but this is a bit of a crap shot as there is not a definitive way to check the keypad.
