Success only with high-limit bypass
Flame for only 2 minutes, then goes out. Checked continuity of high limit thermostat: okay. Checked resistance of flame sensor: okay.
Replaced coils. Same problem.
Replaced high limit thermostat. Same problem
Works perfectly when I bypass the high limit thermostat (remove leads from thermostat and attach together.)
What to do now?
