Found lint at 90, didn’t go farther. Gas dryer, ignites for 10 to 15 seconds then shuts off.??
Scottpiggs
Most likely the problem is clogged vent not the dryer itself. Disconnect the vent hose from the dryer and run one or two loads with the hose disconnected. If the drying time is better then the vent needs cleaning.
Good luck.
The board is what’s responsible for bringing the oven up to set temperature. There is no other sensor, thermostat, etc. You can try adjusting the board first, since the temperature is only off by ~40 degrees. If that doesn’t help, replacing the board should (this GE model has an expensive board - $220).
