I have an electric Tappan stove that the top section won’t heat up. I could not find the model number but found a general troubleshooting schematic. Which give me the p/n 316441457.
Came here to make sure I’m doing things right. Going to check the wires. Check the heating probe. What things should I exactly be looking for? Should I keep the power off and ohm through it to make sure or should I keep power on and carefully check the voltage? What should I be getting?
Also going to check the Element!
It doesn’t give me a Fault code on the electronic timer.
Thank you!!!
