Recently I had the left side of the terminal block melt off. I have replaced the block and checked the wiring. The 14 gauge wire that attaches to that side has become brittle at the end and will need to be removed. My issue is that in doing that the wire is now too short to reach the connection on the terminal properly. So my question is, can I extend the wire and if so do I need a special type of wire to use or can I just use 14 gauge equivalent with a wire nut.
Thanks for the assistance.
