Hi, I have a GE GSS22JEMD side by side. The freezer rear panel is totally frosted up and neither side cools down. Looking thru the other posts following the advice given them. I unplugged fridge while cold and checked ohms across the wires I thought were correct. Orange that says "IN" on the board and Red that says "DFZ" I got 23 ohms,which means I think, that the board needs to be replaced. Is this correct? And can you tell me where to find one if that is the case?..Thanks very much
[SIZE=3]Where are the defrost heater and thermostat located on a GE [/SIZE][SIZE=3]GSS20IEPAWW side by side?[/SIZE] I do not see either part in the diagrams at AppliancePartsPros.com.
It would be apreciated to support this site and order AP4355467 cost $28 versis $36.50 at other sites.
I Agree!!! From the words of "Fast Times at Ridgemont High" " If we cannot be Athlete’s, we must be Athletic Supporters" LOL!!! Just having a little fun!!! Tom http://www.applianceeducator.com
my washer was not draining all the way so i took it apart emptied the boot got $1.85 out of it put it bk together and it still dont work someone said it could be the door switch well i unscrewed it and i dont know how to get to it any suggestions on which are the right screws and what needs to come off to get to it
