testing the on/off switch
The dishwasher won’t start when the on button is depressed. (yes there is power to it.) No lights, nothing happens. I assume it is the switch and not the control board. (I tried that test too, but again nothing happened.) But before I order a new switch, is there a way to test it? I checked the six contacts with an ohm meter. I had continuity between the middle two tabs (black and gray wires) and also two on one end (red/white and white wires) but nothing between the other two. But I don’t know which one are suppose to close when in the ON mode?
Thanks for any help.
