the digital display's gone
The oven was not being used when this happened. We heard a couple of beeps and found that digital display’s gone. No clock. It still makes single beep when buttons are pressed. Still be able to turn on/off the oven lights. Tried to rest circuit breaker a couple time but couldn’t bring it back to lift. Tried to start the upper oven but failed. However, it seems we still could turn on the lower oven. I have read a couple of posts on this forum and it sounds a problem with control thermal fuse. My questions are"
  1. Before I take down the control panel to check the thermal fuse, what else can I do?
  2. If it is not the problem of the thermal fuse, what else can it be?
  3. If it is thermal fuse problem, what is the part # for this specific model?
Thanks,
Ning
