The right control box kit
I purchased the control box kit AP516342 for my refrigerator because the damper was not working on my side by side refrigerator. Replacing the damper did not fix the problem so I was told the temperature control would be the next thing to replace. I decided to spend a little more and get everything new with the control box kit. This did not work. The freezer side did not get cold enough and the blower ran constantly. 2 things different on this control box. There was only 1 set of wires to the motor and the temp control had 2 connectors. My old control box has 2 connections to the motor and 3 connections to the temp control.
Is this the correct control box kit? There seems to be no solution?:confused:
