Thermador 6 burner cook top
I have a cook top that got flooded from a fauset above it that broke. We cleaned all the water out and the left front and back burners would not come on anymore. The other 4 burners worked fine. So I ordered 2 ignighters from you and replaced them. When I pluged in the ignighters they started to click even though I did not turn on the on off control that starts the burner. then the wire harness to the control box sparcked and popped the breaker. I reset the breaker and it did not trip again but now no spark happens but it clicks very softly then it stopped. I wiggled the 6 prong harness and the blue LED light flickers but nothing happens. Did the main inighter control short out or something else? I pulled the harness off and inspected the plug part and it was black et the first two prong oppennings and the pins were scared from the preveous spark the occured before. Could that control be bad too and dose the wire harness need replaced? Help
