The Left Hand Side, Rear burner does not light. It is one of two burners with a low flame simmer control. This burner sparks but appears not to get any gas. All 3 other burners work just fine. I have read posts about the Potentiometer and suspect it may be my problem too. I have three questions:
(1) It seems the original part is no longer available and the currently available potentiometer can only be used with the current version of the gas simmer kit. Does this mean I have to buy the kit with two potentiometers (I think I only need one) and the simmer control? If so, what is the part number I should get?
(2) I am pretty handy but the web site suggests that only a qualified repair person do the job. How seriously should I take this suggestion?
(3) In spite of me thinking I’m pretty handy, I am having trouble removing the stove top to get at all this stuff. I have removed the long brass bolts under all 4 burners but the top does not seem to lift up. Should I try harder to lift it or is there something else holding it down.
Thanks very much for your help.
Charlie
