Thermador Cooktop Igniters
[SIZE=3]Hello, I have a six burner thermador gps366s cooktop and some of the piezo igniters have come loose. They still work if I manually adjust them but since they are loose they just move again during cleaning. I have found the new igniter part on your web site but need some more info on installation.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]What keeps the igniter attached? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Is there another part I need? [/SIZE]
[SIZE=3]Does it install from the bottom? [/SIZE]
[SIZE=3]Is there a good drawing or manual for this?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]thanks, Billy[/SIZE]
Hello Gene,
thanks for the response. I will try to find these rings in the parts list but it is not very clear from the exploded view drawing. I assume that they are some type of spring clip and I guess I will just learn my way thru dis-assembly.
If you have any tips on the sequence of getting the burner base pan out it would be much appreciated.
thanks for your help,
Richard
1vrbilly said:
Hello Gene,
Richard
[SIZE=5][COLOR=#008000]I have a Thermadore Gas Cooktop model PCG364 and I’m need help to replace the Spark ignitor. I believe I have to remove the Burner Ring and I’m trying to find a tool to remove the ring. 1st am I correct that I have to remove the burner ring? and 2nd can you tell me the tool the will allow me to do this?[/SIZE][/COLOR]
1vrbilly said:
Hello Gene,
Richard
Sorry, the correct model # is PCS364GLUS
Hello Gene,
I’ve a Thermador PCS364GLUS and I’am replacing the 4 igniters but i can´t find the part number for the wires that connects them to the control module
Can You help me please with this?
Thanks in advance
