Thermador Double Oven - Model # SC272ZP
Just replaced the broiler heating element in the Top oven.
When I turned on Top oven, it did not work (both elements did not heat up).
I then replace the Top Thermal fuse. When I turned on the Top oven, oven still did not work.
The bottom oven is working just fine.
Any suggestions as to what can cause my Top oven not to work (elements are not heating up)
Thanks in advance,
